Help please - Security light flash - FirebirdV6.com/CamaroV6.com Message Board
  • Help please - Security light flash
    My car ran at 1:30am this morning no problem. I accidently locked my keys in my car later this morning and called a lock smith to check it out. He got his tools and unlocked the car. He did nothing electronically. I tried to start it to go to work but for some reason my security light just flashes. I get all power. I have windows, stereo, lights, horn, everything. I can even switch it into different gears (auto) and I can also hear the oil pump priming up, but no go.
    What the hell is wrong? This is the same key I have always used and there is nothing wrong with they key and I don't have a spare. Any ideas?
    Red 1998 Camaro<br />Mods so far=<br />K&N
    Re: Help please - Security light flash
    unplug the battery for a while (30 min or so). This probably won't work but worth a shot.
      Any other ideas? It is unplugged now... Just giving it some time. I am also about to clean my key with a pencil eraser.
        you might have to call the dealer to reset it. Or autozone might be able to...but I don't want to give you false hope there. Meanwhile, you should catch up on some reading about car hotwiring! Maybe if you could cross the battery with the icm or something. Does your steering wheel unlock with the key in?
          i have the same problem, my security light flashes and dosent let me start my car and have honestly been stuck for a while,. ive tried resetting my battery, doesnt work. i finally ended up smashing my dash in anger and heard a beep, turn the ignition and it started. thought it was nothing but everytime i get in my car i have to hit my dash above my cd console for it to work. so thats how ui fix mine
            that doesnt sound too healthy...loose wires?
              my car has a switch you have to flip then turn the ignition to the "on" position.
                whhhhaaattt thhhheeeee fffffuuuuccckkkk
                  search this, you need to bypass your vats system. the chip in your key is worn or the ign. its self is shot, its easy to bypass dont worry.
                    its ur vats...try a spare key
                    87 Firebird RIP
                    96 Camaro RS RIP
                    94 Patriot Red 1LE Z28 - Sold
                    02 WS6 TA - Sold
                      Indeed your VATS (Vehicle Anti-Thief System) feels its being stolen. It disables your starter and obviously you can't start the car. The problem lies in your ignition lock cylinder...it's basically worn.
                      You can resolve this in three ways. 1, you can spary some carb cleaner in your lock cylinder...this sometimes help clean it and get things working again. 2, Bypass it using shbox's diagram (I did this method). Shbox is your friend. or 3, get a new lock cylinder.
                      http://shbox.com/1/how_tos.html - study #22, use #23 and find the right resistor rating using #24.
                        Yes, my steering wheel DOES unlock with the key in. What does that mean?
                          i did mine a while back.... there's a sticky on the electrical section
                          http://forum.camarov6.com/showthread.php?t=77193
                          <a href=\"http://www.cardomain.com/id/1995birdman\" target=\"_blank\">http://www.cardomain.com/id/1995birdman</a>
                            same thing happened to me and my key was just dirty.lol
                              Pencil eraser works.
                              • 187shark
                                by 187shark
