how fast dose the stock camaro go - FirebirdV6.com/CamaroV6.com Message Board
  • how fast dose the stock camaro go
    i got a v6 3.8L 2001 Just wondering how fast will the speed go to is it governed??
    Re: how fast dose the stock camaro go
    118 mph
      I went over 125 My thign never shut Off My car cpu is a M5 but i put a 700r4 Tranny in it and never switched the pcu so I guess that makes the Pcu confused on the speed? because my speedo is correct i Tested it and made the speed sensor
        doesn't matter............do the speed limit.................:slap:
        WAWA-A-HOLIC
          I topped at 116 I believe
          1998 Red T-top V6 Camaro
          - K&N Filter, Pacesetter Headders, MagnaFlow 2.5" Hi-Flo Cat, FlowMaster 80 Series, PowerDyne Supercharger@9Psi More 2 Come
            118..
            Let's flip a coin. Heads I get tail, Tails I get head.
              I'm sure he was in a controlled environment.:bs::):rolleyes:
                Ungoverned I would think the 3.8's can go about 140? Interesting to try, but I don't dare.
                  with the stock tire size and the t5 3.42 gears you should be able to hit around 175 at redline
                  i topped out at exactly 118 in 5th gear around 3500rpm
                    In a vacuum, sure. The tricky part is carrying enough oxygen on-board for the engine to run.
                    Lounge Moderator
                      i can confirm 149.7 (not stock of course)
                        hi,
                        i have a 3.8V6 Camaro and i did drive 200 km/h, this is about 125 miles/h, and she could be faster, if i wouldn't had slow down because of the traffic.
                        My Camaro is stock, except the shocks (replaced by Koni's) and the swaybars (replaced by SS-swaybars 32mm and 19mm)
                        This is an European camaro, i removed the speed limiter with my hypertech 320002.
                        Patrick
                          Interesting mirrors.
                          Lounge Moderator
                            hi Bonemaro,
                            Because i am living in Europe (Netherlands), i have a Camaro with some adjustments for the European Market.
                            These changes are:
                            - km speedometer instead of miles.
                            - seats with adjustabele headrests (they are same as the firebird).
                            - mirrors are differrent because if you hit a bicycle or someone, they could be injured.
                            - the lights on the back of the car, (fog lights) and no red lights on the side of the bumper.
                            - and some more small changes.
                            Patrick
                              I've been trying to figure out how to acquire one of those rear bumper covers. Any ideas?
                              Lounge Moderator
