1FP87 ?? - FirebirdV6.com/CamaroV6.com Message Board
1FP87 ??
  • 1FP87 ??
    I was checking into the codes in my glove box to see what my car had in it from the factory (bought it used privatly ) , and the only codes I could find that were anything close to the ones I've seen you guys talking about are : 1FP87 , & GU5 I have a 94' Auto 3.4 Camaro. Anyone know what these codes mean? [img]graemlins/rofl.gif[/img]
    3200 Stall , !FRA , K&N , Custom Intake , Dynomax Exhaust , 180 Thermo......Lots of weight reduction
    GU5 = 3.23s
      my dad and i figured that one out recently....but what does 1FP87 mean?
        Refer to our Technical Database:
        http://tech.firebirdv6.com/RPOcodes.html
        Raven
          GU5 is the RPO (Regular Production Option) for a 3.23 rear axle ratio.
          1FP87 is the Manufactuer's Model Code stating the make, vehicle model, series and body type.
          The info I've got shows 1FP87 is the code for a 2-door coupe (RWD) Camaro. [img]graemlins/burnout.gif[/img]
          Zobe
            I just checked my 2001 Camaro..and while its not a Y87, it is still an RS ; has 3.42 gears, and the code Y3B, which is the Camaro RS code. so...neener neener....i knew my Camaro kicked a**!!
              <blockquote>quote:</font><hr>Originally posted by rebelmark:
              I just checked my 2001 Camaro..and while its not a Y87, it is still an RS ; has 3.42 gears, and the code Y3B, which is the Camaro RS code. so...neener neener....i knew my Camaro kicked a**!!<hr></blockquote>
              one of 398 [img]graemlins/thumbsup.gif[/img]
              <a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
                2 days ago
              • Doodler
                97 Camaro base with expensive sounding noises
                by Doodler
                Still trying to find oil leak
