When I hit my power window switch when I'm sitting still (once it is up or down all the way) it makes the dial on my RPM gauge jump up to different rpm levels. I never noticed it until now, what do you think the problem is? When I'm driving it doesn't do it.
What is wrong?
Re: What is wrong?
Originally posted by dobie View PostYou're putting a load on the alternator causing the computer to compensate by adjusting engine speed. Nothing to worry about although if your battery is old it probably will be needing replaced sometime soon.
TEAM C6V6
Re: What is wrong?
Originally posted by Blizzard242 View PostIf thats true then I just learned something new. :) It makes sense. I did however solve my low voltage numbers but installing larger gauge ground wires like most people have on this site.
when you turn your lights on at night, and are sitting still it does it a lot more.. same with turning the blower fan on
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
