ok i have a tci 3200 stall a transmission cooler and a hypertech on the way. My best run is a 16.4 with gears and free ram air mod. my 60 ft is 2.5 and i was wandering if these should drop me to a 15.9?? another thing is this to much of a stall for my car. its a 2000 auto firebird
tci 3200 stall and a hypertech..waist of money or good mods
i have a 3200 stall in my 94 A4 V6 Camaro and i love it. It's damn fun....you can actually feel it kick in even when ur normal driving....and it helped A TON with street races off the line. I recently took a 92' 3000GT N/A by 5 car lengths before i hit 60mph because of my 3200 stall.3200 Stall , !FRA , K&N , Custom Intake , Dynomax Exhaust , 180 Thermo......Lots of weight reduction
Well if you get some drag radials you would have been in the 15s with your older mods, your 60s should be alot less than 2.5 that shows you have major traction loss. Im afraid without sticky tires your times will be worse because the high stall will definately spin the tires more, its the traction that is killing you.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
I know I mentioned this on LRS also, but I think you have a good plan. Drag radials are a must! I am loving my nittos! Between the TCI, hypertech, and gears, I don't see any way that you won't be running in the 15's.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
you shouldn't have a 60' of 2.5 if you have no traction problems [img]smile.gif[/img] But then again maybe you have other things to worry about other than traction...-Chad<br /><a href=\"http://members.cardomain.com/chiknz\" target=\"_blank\">2001 3.8L A4 Camaro</a>
Should definitely help!! You should be cutting a 2.1-2.2 instead of a 2.5. Your car has mid to high 15 in it the way it is. If you get your stuff together you may be able to hit a low 15. Goodluck [img]graemlins/burnout.gif[/img]<b>Red 1999 Firebird M5</b><br />Whisper Lid,Borla Catback,K&N,Dual Friction Center Force Clutch,Hurst Shifter w/Lou\'s Short Stick,!FRA,Suncoast Ramair hood,160 Thermo,!maf,Chrome ZO6 Wheels, Painted Calipers, CIA Headers, Taylor Wires, NGK Spark Plugs, 3\" Catco, Jet Chip Stage II, BMR STB, LCA, PHR, SFC, Fan Switch, FTRA<br /><b>Old Dyno Numbers: 183 RWHP, 217 RWTRQ</b><br /><a href=\"http://community.webshots.com/user/redsixer\" target=\"_blank\">http://community.webshots.com/user/redsixer</a>
<blockquote>quote:</font><hr>Originally posted by ChikNz:
you shouldn't have a 60' of 2.5 if you have no traction problems [img]smile.gif[/img] But then again maybe you have other things to worry about other than traction...<hr></blockquote>
Maybe you have never run your car around here. Altitude is 3300+, but density al;titude is rarely better than 4000ft. This affects 60' times just as much as ET's.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
Nope, waiting for some suspension stuff first. I'm getting an apartment in less than a month, and am saving my money where I can. Until I gett he suspension stuff all on, I am gonna hold off on filling the bottle even.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
