low beam connector - FirebirdV6.com/CamaroV6.com Message Board
low beam connector
  • low beam connector
    the little plastic clip thats supposed to hold the blades on the driver side low beam light is in all the way and yet the blades keep backing out allowing the connector to disconnect and fall away. any ideas
    thanx in advance
    <a href=\"http://cardomain.com/id/fantomfreke\" target=\"_blank\">http://cardomain.com/id/fantomfreke</a> <br />** Bad American **<br /><br />*2000 F150 4x4 off road*<br /><a href=\"http://cardomain.com/id/fantomfrekesford\" target=\"_blank\">http://cardomain.com/id/fantomfrekesford</a>
    just put a dab of household silicone glue on the end of the connector and push it back together.. that will hold it, but when you do ever have to swap the bulb it should come apart with a little extra force.. just don't go nuts with it..
    if you have some rtv lying around that should work too.. like I said just use a dab or 2..
    [ March 18, 2003: Message edited by: black98V6 ]</p>
    -Brad
    2000 V-Star Custom 1100
    :rock:
      ill give it a shot, apreciate it
      • 187shark
        by 187shark
