some times when i push my clutch in the rpm get really low and the car feels like it going to die.
car feel likes it wants to die
Re: car feel likes it wants to die
how often does it do that?
the computer is shutting the injectors off when you press the clutch in until it hits idle, once it hits idle your injectors turn back on, sometimes if the engine isnt warmed up, etc it can act like it wants to doe
Originally posted by gugdathug3 View Postany lights on the cluster? any leaks? does it like bog or shutter?
my Lt-1 did someting like that like a week ago..air pump needed to be bled.
Originally posted by 95firebird3.4 View Postno lights and no leaks that i no of. and idk what the diff is between bog and shutter. how do u bleed the air pump.
a shutter is when your car literally shakes like you have a misfire
Originally posted by 95firebird3.4 View Postok so its more like a shutter
when you press the clutch in, your injectors turn off like i said
sometimes if you press it in too fast, and the engine isnt "ready" for it it will dip a few hundred rpm below idle, shake for a second or two and go back to idiling again
this can happen in neutral and when you hit the gas and let off very quickly
have you tried using injector cleaner, or changing your fuel filter?
the likely cause is fuel related
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
