!A/C removed, now no Heater? - FirebirdV6.com/CamaroV6.com Message Board
  • !A/C removed, now no Heater?
    I removed my A/c, now the heater only blows cold.
    I'm thinking I gotta have something plugged up or something?
    plz help
    What do you need heat for in hell?
    Did you remove the heater core?
      I hope you didnt remove heater core ^^^^^
        [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img] [img]graemlins/rofl.gif[/img]
        05' CTS-V
        00' Camaro - SOLD :(
          no, i didnt remove the heater core itself.
          that would be hard to get to.
          i just removed the condenser lines.
          what would happen if you removed the HC?
            it aint hot enough in hell
              So what exactly did you remove? Compressor? condensor? evaporator? lines?
                ......you would have the problem your having now...no heat
                  where do you live that you dont need a/c?
                    same place you do
                    so what do I have to do to get the heater back?
                    reconnect the condenser lines?
                    on the other side of the condenser it hooks up to the evaporator(A/C radiator)
                    i removed the evaporator too
                      The AC should not have anything to do with it. Did it quit working right after you disconnected the ac. If you live near me bring it by and lets see it. Check to coolant level. The fan inside the car still blows right. Are the two heater hoses hot?
                        You ran the belt back around the water pump....right?
                          the belt is definately turning the water pump
                          sorry, i would love to take the drive but I have 4.10s ;)
                            is it spinning the water pump the right way? It its spinning the wrong way the heater hoses have a check valve built into on of them. It will still kind of cool the engine, but you will have no heat
