Did he do something wrong?
Re: Did he do something wrong?
Originally posted by tkoforpresident View Postits ok man :wavey:
we're just messin with ya.
if it turns out bein the alternator, my next paycheck is yours ;)
well if its the alternator you cant have my paycheck but you get 1,000,000 cool points and i will come to you from now on because of your amazing automotive abilitys
Well I'm getting the fuel pressure checked out tomorrow see if thats good does anyone know what the pressure should be? Could it also be the fuel pressure regulator? But it dosen't do it all the time it's like this if the car is off for more then hour then it takes about 3-4 seconds to start but if it's off for less it fires right up.
Originally posted by Leonard 3.8L View PostI tried.
05' CTS-V
00' Camaro - SOLD :(
Well it just sounds like you're loosing pressure in your lines.. and this was the first I've learned of a check valve in the fuel filter but that's a good place to start. I'd say go to autozone or somewhere of the sort, get a new fuel filter since they are cheap and change it yourself. It's easy. If you need help doing it then there are a ton of people here more than willing.
BTW to temporarily fix the problem turn the key to the on position for like 10 seconds before you start it to let the pump prime. Ah, you already knew that. I'm just reading through all the posts now lol. Truekoa had the same problem but worse.
http://forum.camarov6.com/showthread.php?t=91244
Did your mechanic do any other work on the car?Last edited by Blizzard242; 07-01-2008, 11:01 PM.
TEAM C6V6
Originally posted by nikon View Postbut did ya think before you spoke? not tryin to be an ***...just trying to figure out how and why you would even think of associating an alternator with a hard start.......it really has nothing to do with it....not even close...wtf is a rectifier anyways??
:D
