seems like there's some water/condensation in my one front turn signal, but the bulb still works fine
anyway to fix it? should i just try to make sure it's tight and connected and everything?
I had the same problem except i was going throught bulbs like once a month. I took mine out and drilled three or four holes in the bottom of the housing. This was about 3 months ago and seems to have solved the problem.
The problem is the DRL's are melting the cheap plastic housing around the bulb socket. Everyone I know with clear corners and DRL's have that problem. However, those I know who don't have DRL's (pre-97) don't have that problem. When I installed my clear corners, I disabled my DRL's. It's been a year now with no problems! ;)
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...
