my ac is gone and so far no one can find whats wrong.when i fill it with freeon it works great for about 12 hours but after that its done so i think i have a leak a big one. what i would like to know is how much have you guys paid to have your ac fixed firestone wants $550 to fix
A/C repair
Re: A/C repair
they shouldnt be able to give you the price because they dont know where the leak is, could be a number of different places. and if theyre charging you that much to find the leak, thats ridiculous. if you have the tool, finding a leak should take no more than a few minutes, especially if its a big leak like youre saying.
Re: A/C repair
best way to find a leak is to fill it with UV leak detector before you charge it again, let it sit for a bit, and when it gets dark look at it under a black light.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Team Black...TEAM EMO
Come on kids! Get a Calendar!
Re: A/C repair
If you have not already, try using the R134A with the O Ring conditioner and see if that helps. That will eliminate or at least reduce the leak if it has to do with the compressor seal or any other rubber seals. At the same time use some of the stuff with the UV dye. If the seal conditioner doesn't help, then you'll have to pinpoint that leak. I would suppose that if you cannot find the UV dye trail anywhere under the hood, that would mean that the leak is in the evaporator. Good luck.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Re: A/C repair
Originally posted by Firebirdkid96 View Postbest way to find a leak is to fill it with UV leak detector before you charge it again, let it sit for a bit, and when it gets dark look at it under a black light.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: A/C repair
ok firestoner gave me a real qoute get ready)))>>$956.84 :eek::mad::rant:
the list of whats needed.
1.new drier/accum $59.54 (labor) $53.00
2.new evaperator $347.21 (labor) $247.00
3.orifice tube $6 (labor)44.00
4.(labor) a/c evac&recharge $113.99
tax and such = :spank:$956.84
Re: A/C repair
$44 labor on a ****ing orifice tube?!
bull ****!
do it yourself man, it'll be so much better
you're gettting *** raped by firestone for all that.Y87 Package
MOGOB APPROVED!
BONE APPROVED!
VANBIBBER APPROVED!
KRISTEN APPROVED!
Vice Prez.
Re: A/C repair
i must have got one of those rare cars that came with windows.
youll save a lot of money by doing it yourself, but as far as charging and discharging, make sure you have an place do it properly. dont bother with those junk fill it yourself BS.
Re: A/C repair
I have a quick question. I am also troubleshooting a A/C System. My compressor shutdown and the clutch wont engage. Paid 50 bucks for a dealership to tell me I need a new compressor. The one I have now has seals that leak. Basically they want to sell me a new one installed for 647.00. Nah... I will do it myself.
I figured that it had leaked down so low that the low pressure sensor shut it down for low pressure. My question is, that if I want to gas it back up, alot of people say to unplug the low pressure sensor and jump it out to restart the compressor. That way I have it running so I can add some stop leak. Ok, I have looked and dont see it. I saw one sensor but it has 3 wires running to it. Not sure thats it. So am I headed in the right direction and if I am, where is the sensor located at and what does it look like?
Keep in mind, all relays and fuses are good. Compressor clutch will turn easy and is not locked down. My camaro is a 2000 V6 3800. If I do decide to change out the compressor, is there any directions out there someone can help me with removing and installing another. I have help with evacuating and charging the system thanks to a A/C buddy of mine. Thanks guys for any help you can provide including pictures.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...13 hours ago
