Will LS1 injectors be plug n play for us?
LS1 Injectors
Re: LS1 Injectors
Ya, I plan on getting a tune before I put them in. I just wanted to up them a tad bit to make sure I don't push the stockers to their limit. They're from a '00 F-body, so I think they'll be a direct swap to my 97.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: LS1 Injectors
yea check the pinstyle on them and make sure it is the correct style. You need the shorty injectors and not the tall skinny ones.
Re: LS1 Injectors
General information:
97-98 LS1- 28# injectors
99-00 LS1- 26# injectors
01-02 LS1- 28# injectors-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Re: LS1 Injectors
Go #36lb gtp injectors for $50-60 dollars, they are outstanding. I ran them with my powerdyne kit and now still running them with my nitrous setup. I was running a wet kit , now I have switched to a dry. I'm glad I left the injectors in. For $50 you can't beat it.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: LS1 Injectors
Originally posted by Smoke Panther View Postit is, if you match the style/year (multitec or bosch) of LS1 injector to your car. Also, the car will run rich until you adjust the tune for the injectorsmy other truck has a 50 cal mounted on it
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...6 hours ago
