Ok, here are my questions, what speed do stock 3.4L and 3.8L engines idle at?
Does the transmission make a difference, and if so, assume it's an automatic transmission.
2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
New Toy Red 94 Formula LT1
RT: .0006 60': 1.894 1/8 mile: 8.351 @ 84.89 1/4 mile: 12.974 @ 107.81
crashed Red 96 Camaro 3.8l: 14.91 @ 92.38
The ex wife's Black 98 Firebird 3.8l: 15.23 @ 88.12
I ask cause when I put my glow gauges on, the tach is always off. The way I fix that is by starting the car and putting the tach needle on while running.
(the instrument cluster is a Z28 cluster too, but
I rewired a few things and it has been accurate, but I want to know the 3.8L idle so I will know if it is pretty much on with the 3.8 I will be installing.
Well, I installed them without removing the needles, so everything worked. The new gauges work great, and I'll take a pic and add them to the appearance section.
Thanks for the help everyone!
