coolant questions - FirebirdV6.com/CamaroV6.com Message Board
coolant questions
  • coolant questions
    I flushed my coolant monday with the prestone heater hose thing. Now I have filled the radiator with a 50/50 mix of green antifreeze/water, but the engine block holds more than half of the coolant, which is now mostly water i would assume after the flush. is there a way to get that out.
    now my next question. I ran water through the overflow reservoir also, and now i cant get it out. I took the overflow tube off of the radiator, but nothing will come out of it. But when I blow on the hose, you can tell that it the overflow reservoir has fluid in it. And the coolant dipstick shows that it is past the full mark.
    <a href=\"http://www.cardomain.com/memberpage/483076\" target=\"_blank\">http://www.cardomain.com/memberpage/483076</a> <br />TSP rumbler, straight pipe, corvette servo. <br />Soon - 3.42+lsd,headers, cai,
    ...try starting the car with drain open and monitor the temp....just a thought
      the knock sensors act as drains for the engine block.
      to empty the overflow either remove the battery and the tank itself or get a little siphon pump.
