ABS INOP LIGHT- WHAT DOES IT MEAN!? - FirebirdV6.com/CamaroV6.com Message Board
  • ABS INOP LIGHT- WHAT DOES IT MEAN!?
    So i pulled a code for a multiple missfire problem. I got home, and the ABS inop light was on - what does that mean!?
    -Justin-<br />Red 1996 Camaro RS- Wrecked 11-1-03...<br /><br />1991 Camaro RS
    means your abs isn't funcitoning.. could be bad ground, or loose sensor plug... or bad sensor.
    Moving this to general tech.
    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
      ehh the light went away-- mabye it wont come back!
        when i had gotten my car that light came on. So i searched ''abs inop'' and this forum came up [img]smile.gif[/img] So i started doing a search and it turned out that the reason for the light was that my 3rd brake light bulb was burned out.
        i replaced it, and since then the light hasnt returned.
        My car has GPS trackin\',traffic alert,its own phone #,PS2,screens. And What da H3ll,When I Turn da key it says \"You\'ve got mail\"..... <br />I swear and promise.. I\'ve had more cars then Charlie Thomas.. bounces in a Monte\' that hopped.. Pimped old skoo Blazer on Chopz, Today Its a Camaro at all da plya spots.
          LoL thats hilarious... let me think, mine was comin on a while ago... Dont remember why, but it usually was doing that when I was messing with My cai and doing the occasional WOT then brake hard. turned out I had a bad caliper that I changed a few months later. the light didnt stay on. I just had to turn the car on and off. but it turned out the caliper was locking up. Rear driver side. - but only when I would get all teh way into the brakes. thats just me,.
          97 Special Edition Bird , Short bus stlye special
            It means several things. Most common, low voltage. Whcih leads to your alternator going out or a bad cell in the battery.
            94 Quasar Blue Z28<br /><a href=\"http://www.9t4z28.com\" target=\"_blank\">http://www.9t4z28.com</a><br /><a href=\"http://www.9t4z28.com/Dyno1.htm\" target=\"_blank\">http://www.9t4z28.com/Dyno1.htm</a>
              <blockquote>quote:</font><hr>It means several things. Most common, low voltage. Whcih leads to your alternator going out or a bad cell in the battery. <hr></blockquote>
              actually i think your right. when i wrecked the RS in november, the shop had a problem with the alarm going off every 2 seconds, and kept un-doing the positive side of the battery terminal. caused the bolt to wear out.
              i had jimmy rigged it to bring it home, and put it away for the winter- not thinking of the battery. i had pulled in the driveway yesterday and the car wouldnt re-start. popped the hood and the conncetion came out.
              fixed the problem by goin to circut city and getting a GM bolt of systems. That should fix the problem, as well as make it easier to connect and disconnect the system.
              thanks for the help!
