So i went to subway for lunch. Car is fine from here to their. i get out go get my lunch and return about 5 minutes later. i turn the key to on and let the fuel pump prime as usual. Nothing wierd so far, all the dash lights light up. I go to crank it and......nothing happens. Not even a sound. It acts just like it does if you try and crank it without the clutch pressed in. any quick ideas before i call the shop to come pick it up? This is an 01 3.8 m5 if it matters.
Car wont start
Re: Car wont start
I havent tried to start it with the heater on....if i do so and it does or doesnt turn on, what would this tell me? i was either thinking starter switch, or im sure their is some kind of switch that tells the computer that the clutch is pressed to allow it to start. anyone heard of these going bad?
Re: Car wont start
that's what i was saying. On my car, if the heater fan is on and my clutch isn't pressed in, the fan will turn off when i try to crank it...
edit. check this thread.
http://forum.camarov6.com/showthread...starter+switchLast edited by onspeed; 07-09-2008, 03:14 PM.
Re: Car wont start
ok little update. went to the car after work. i cleaned the key real good and tried to start it. Still the same thing. So i pulled the clutch switch off and used a paper piece of wire to loop it, and still the same thing. At that point i was so pissed at scratching up my enitre arm trying to get that thing out that i just called a tow truck. Im guessing its going to be either the starter soleniod or the starter itself. Waiting on my mechanic to give me a call today. I really cant afford much to be wrong with it right now. Any idea on prices of either of those two things?
Re: Car wont start
Finally talked to the shop today and learn that my starter has taken a dump on me. No problem its only going to be 90 to fix it including parts and labor. On a side note, it was damn 80 bucks to tow it to the shop, next time i will tie a rope to the bastard and pull it up their myself if i have too.
Re: Car wont start
Thats a good price for parts and labor, sounds like a honest mechanic, you often don't see to many. Did you have any signs prior that it was telling you that it was going out, like hard starts or anything?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Re: Car wont start
Now that i think back their were prolly a few small symptoms. I remeber before when trying to crank it, i would turn the key over and it would hesitate for a second before the starting action would take place. This is the only thing i remember though. I am very happy with the mechanic i currently use. He recently did a complete motor swap for me including switching all accessories, all new fluids, and a few small misc. parts for around 300 bucks. He is also good about doing small stuff for free, just saying he likes to keep the customers he has and dont mind the small stuff. As much as i like him though, hopefully i dont need to see him for a while after this lol.
Re: Car wont start
I just know a few mechanics through the dealerships where my dad worked for GM for 40 years, so I take it to them and have the service writer make sure their the ones that do work on my car. Plus I always go back and talk to them. I have the lifetime warranties on my A/C compressor, starter, Alt, and water pump still since I'm the Org. owner. Good luck on yours.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
