coolant leak - FirebirdV6.com/CamaroV6.com Message Board
coolant leak
  • coolant leak
    i have a coolant leak behind and above the water pump. is this the lower intake gasket, or could it be something else? ( it's not coming from the thermostat or hose...)
    Re: coolant leak
    sounds like the lower coolant elbow from the lower intake to the heater hose manifold is cracked. pour some ground pepper in it until you can fix it.
    Y87 Package
    MANUAL CONVERTED, Pro 5.0 Shifter
    Pacesetters, Magnaflow Cat, Cutout, Flowmaster
    MOGOB APPROVED!
    BONE APPROVED!
    VANBIBBER APPROVED!
    KRISTEN APPROVED!
    Vice Prez.
    Team Black...TEAM EMO
    Come on kids! Get a Calendar!
      Re: coolant leak
      Yup.
      What??
      F that. Its a $3 elbow that takes less than an hour to replace. Just get a new one and fix it.
      1997 Camaro RS A4
      2006 Chevy Colorado
      2003 Kawasaki Ninja ZX6-R
        Re: coolant leak
        Originally posted by Shodown View Post
        Yup.
        What??
        agreed with the fixing part, but
        you've never heard of using pepper to stop a coolant leak? the big pepper particles try to flow out through the leak and clog the leak shut temporarily
        Y87 Package
        MOGOB APPROVED!
        BONE APPROVED!
        VANBIBBER APPROVED!
        KRISTEN APPROVED!
        Vice Prez.
          Re: coolant leak
          That sounds shady. I wouldnt put pepper or any other stop-leak stuff my coolant system...ever.
          1997 Camaro RS A4
          2006 Chevy Colorado
            Re: coolant leak
            I heard of someone pouring 151 in their gas tank just to make it to a station to fill up. Dumbest thing I've ever heard of.
            TEAM C6V6
              Re: coolant leak
              I would try a marketed stopleak, but back in high school when you need to get home and had a coolant leak, this work great....
              Y87 Package
              MOGOB APPROVED!
              BONE APPROVED!
              VANBIBBER APPROVED!
              KRISTEN APPROVED!
              Vice Prez.
              • Andy H
                Transmission removal help!!
                by Andy H
              • 2.8 Bird
                Abs inop
                by 2.8 Bird
              • fishin
                by fishin
