to change to synthetic oil on a car with 50k?
is it a bad idea
Re: is it a bad idea
Originally posted by FadeToBlak121 View Postpeople say that synthetic oil is only good if you used it from day one. but in reality, i doubt itll do a single bad thing
if you have a higher mileage engine, especially one that has any kind of leak, you will be screwed
putting the synthetic in will definitely show you where your leaks are
Originally posted by tkoforpresident View Posti got a 93 3.4 with 93k miles on it.
i recently changed the valve cover and LIM gaskets.
It does not leak oil right now.
what do you think of me switching?
if what you are using now is fine.. why change?
If you don't have any leaks on your engine righ now then I think you would be fine changing over. I did using RP 10w/30 and it runs great. I even went to RP in the rear end. I also went with Valvoline dexron VI syn. in the tranny. Runs great.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
One benefit is better oil for the internals also you can go more without changing oil, but I do change mine at 4,000 now instead of 3,000. Just for the peace of mind, still worries me not changing it at 3,000 since I'm so use to it. I just started last year using RP.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
My car was converted to synthetic oil (Mobil1) at over 100k miles and it still runs great. The Mobil1 oil says that it's good for 15k miles, but I still usually change it every 3-5k. After 5k miles, the oil level was still where it should have been.
