Well My Camaro needs a new timing belt and I was wonder if that was something I could change myself I've never changed one before. I was told that If it was put on wrong that I would blow my valves is there some kind of trick or should I take to a shop? Or is it easy a enough where I can take the old one off and put the new one on with no probelm?
Oh sorry I guess it's the drive belt in the front of the engine the belt on the alernator it is very badly cranked all over and I need a new one and was wondering if I could change that my self?
Dude, that takes literally less than 5 mins to change lol.
15mm wrench on the tensioner pulley is the only tool needed. Push the pulley down, take off the old belt, put new belt on (routed correctly, there is a diagram under the hood) and you're done :)
yeah thats real easy. just put a socket on the tensioner. I think its like a 15 mm. and push down on it and itll loosen the belt. take it off and make sure you follow the belt routing diagram if youve never done one and just put it on like it says to and release the tensioner and itll tighten up. takes like 2 minutes to do.
for future reference, that's called your serpentine belt
