Abs Inop + Low Oil - FirebirdV6.com/CamaroV6.com Message Board
Abs Inop + Low Oil
  • #31
    Re: Abs Inop + Low Oil
    check your dip stick..that might be leaking where it goes in the block.....jack *** mechanic.....
    • #32
      good idea, check when it's running or when its off?
      • #33
        off if it looks wet then check when its running
        • #34
          my abs inop light has been on for about almost a week now. its comes and goes like you also said. ive kinda noticed(when the abs inop isnt on) that when i crank the weel hard it turns on.(cause it happens often i guess so i look for minor things that cause this stuff) so if u know how to fix this it would be great. im thinking it might be a loose wire or some thing but i dont really know jack **** about these cars as i jsut started modding mine :)
          • #35
            Max - you really need to get a new dipstick, dipstick tube, or whatever else you need to check the oil.
            Don't rely on the "low oil" light. Invest the money and fix the dipstick and tube.
            BTW - As you know I have a 3.4 as well. Personally, I think it is a great engine. Mine runs very smooth and does not burn any oil at all. When I bought the car the "Low Oil" light was always on. The sensor wiring had been cut, so I pulled the bulb and no more "low oil" light issues. I pull the dipstick once a week to make sure it is full and I am done.
            • #36
              thanks man :tup:
              any thoughts out there on how to go about replacing the dipstick and tube?
              how is it bolted into the block? how do u replace it?
              • #37
                hi guys,,,it has been a long time,,,heheheh,,,as for the low oil i think you guys figured it out already,,,,,,,,as for the inop abs,that lights comes on when your brake pads or shoes or worn too,,check that,,,,3.4 is a nice engine,,,,head swap or turbo it.
                • #38
                  thats funny, i just replaced my front brakes 1 year ago....
                  i thought thats what the "brake" light is for.
                  • #39
                    yes my friend,,it comes on when the brakes are worn out,,,the brake light comes on when your hand brake is aplied and when you have low brake fluid,. check your rear brakes then just to be sure.
                    • #40
                      sorry noob question, how do i "check" them?
                      • #41
                        sorry for my improper english,im from aruba.... but is very easy,,the front you check them by a thing that start to squeeck on the rotor,,,the rear ones ,remove the hub and inspect them,,,that easy!!
                        • 187shark
                          by 187shark
