speedo meter gone wild - FirebirdV6.com/CamaroV6.com Message Board
  • speedo meter gone wild
    hi guys,,for a while now my speed o meter is just going crazy,,,up and down,,,,sometimes it works fine,,,im sure is not the speed sensor because my automatic trans works fine... whats wrong??
    Re: speedo meter gone wild
    happened to my friend. unplug battery. kick car swiftly. wait 30. apologise. plug battery back in.
      im so tired of that crazy speedometer that i will add some punches too and i wont aplogise either!!! thanx,,i will do that!!
        Sometimes a wierd speedometer results from alternator problems.
          check your grounds under the hood also, buddy of mine had a problem about like yours and he had a broken ground strap on the drivers side.
          Follow me!
          Or this
            did you notice some voltage-drops when your speedo was going crazy?
            Leonard
            www.fquick.com/96V6Junkie
              you know,,,,when i run my a/c i notice that the pointer goes at the biginning of the red zone,,,on cold start the pointer is very high,the rest of the times it is very close to the red zone,,,i noticed that when my altnator went bad,i had it fixed,then i started to see the very closeniss to the red zone thing..
                Get a voltmeter and check the voltage at the battery terminals while the car is running. it should be somewhere around 14 volts. If it's lower than that, like 13 or less, then you need an alternator. Even 13 is probably too low.
                  13.8 is where its supposed to be.
                  Leonard
