hi guys,,for a while now my speed o meter is just going crazy,,,up and down,,,,sometimes it works fine,,,im sure is not the speed sensor because my automatic trans works fine... whats wrong??
speedo meter gone wild
Re: speedo meter gone wild
Originally posted by 3.4orNothing View Posthi guys,,for a while now my speed o meter is just going crazy,,,up and down,,,,sometimes it works fine,,,im sure is not the speed sensor because my automatic trans works fine... whats wrong??
check your grounds under the hood also, buddy of mine had a problem about like yours and he had a broken ground strap on the drivers side.
Follow me!
Or this
did you notice some voltage-drops when your speedo was going crazy?Last edited by Leonard 3.8L; 07-19-2008, 05:38 PM.
Originally posted by Leonard 3.8L View Postdid you notice some voltage-drops when your speedo was going crazy?
Get a voltmeter and check the voltage at the battery terminals while the car is running. it should be somewhere around 14 volts. If it's lower than that, like 13 or less, then you need an alternator. Even 13 is probably too low.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...4 weeks ago
