I just installed a stant 180, when I removed the stock 195 I noticed it had a little hole on the flange of the stat for coolant to bleed through.Whats this hole for? The replacement thermostat didn't have it.
Thermostat
Actually the hole is what makes the stock stat a 195.
Each one of those holes is approx 5°F drop in temp when you see how the thermostat acts.
They install a 200°F spring stat and have a hole drilled in it to make it 195°F.
Do not worry [img]smile.gif[/img] All is normal.2002 5-spd NBM Camaro
Details: www.1lev6.com
<blockquote>quote:</font><hr>Actually the hole is what makes the stock stat a 195.
<hr></blockquote>
Would that mean if I had a hole or two in a 180 stat I'm getting ready to put in it wouldn't open at 180 (1 hole = 175, 2=170)??? Assuming the same size hole.
RonI know - Camaro 67-02.. 2000 Camaro V6/A4 Black T-Tops<br />1969 Camaro 350/PG 12.69 @ 102.5 1966 Chevy II Wagon 283/PG Destined for NHRA stock eliminator.
No it would still open when the temperature reaches a critical point.
The thing to remember is these are temperature controlled spring valves... a 180F stat might be slightly open at 178F, and fully open by 190F.
What the holes do is allow a little bit more flow until its fully open, and that is like it being more open even though it isnt. (Does that make sense?)2002 5-spd NBM Camaro
Ooops -
Yea, didn't mean it changed the opening point of the spring.... Thanks for the clarification Dominic - that made sense. We did a trick with our "old" 350 in an 84 I had (NOT original). Those had a bypass in the block/water pump to avoid pressure build up before the stat opened, so to get slightly better pump flow, we tapped that hole and plugged it with a pipe plug to force all the water through the pump impeller and then drilled four holes in the stat housing to avoid the pressure build up.
Thanks again Dominic - good explanation.
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...6 hours ago
