questions on o2 sim and other components - FirebirdV6.com/CamaroV6.com Message Board
  • questions on o2 sim and other components
    Iv'e been looking at some bolt ons to put into my 96 camaro. First things first. I need a post cat 02 sim. On 3800performance.com they have on but it says for 98-02 Will this work on my 96? If not, what o2 sim will because I need to get rid of this check engine light!
    http://www.3800performance.com/Merch...oduct_Count=16
    There are two other mods including MSD Blaster Coil Packs and the IWin 1.9 ratio rockers for 98-02 camaro's. Will they work on my 96 also?
    http://www.3800performance.com/Merch...roduct_Count=3
    http://www.3800performance.com/Merch...roduct_Count=1
    Thanks in advance.
    1996 white camaro M5<br />-Custom CAI, !MAF, !EGR, Hi-Flow Cat, Magnaflow Cat-back, Removed Jack/Spare/Back seats.<br /><br />2.12 60\' Best<br />15.14 @ 90 1/4 mile Best
    Think it will only fit 97+. Pretty sure that's when they got the new connector. Try a search in Intake/Exhaust to find it.
    Coils will fit any V6, as they're all the same. However, don't expect to see any difference.
    Rockers will fit, but really read up on them first. Such as what should be done before and with them.
    Matt
    1998 Mystic Teal Camaro M5
      thanks. I have the same connector in that pic. Napa and autozone have given me o2 sensors with the wrong connectors before, so maybe there is some confusion with part numbers, but if its the same connector, it will work fine? Thanks for the response!
        Do you have square or flat connector? If you have a square connector it should work. Maybe 96 got the new connector style...that's quite possible.
        Matt
          square front and back
            It's also worth noting that if you plan on getting a tuner (HP Tuners or DHP) you can turn that code off without a need for the simulator.
            Matt
