car running cooler - FirebirdV6.com/CamaroV6.com Message Board
car running cooler
  • car running cooler
    what are some things i can do to make my engine run cooler?
    Re: car running cooler
    the manual fan switch mod would probably be the way to go. Thats just my guess though.
    http://forum.camarov6.com/showthread.php?t=77114
      oh yeah i forgot about that. I may do that if i dont come up with much else, I dont really have the time to do it right now. but thanks for the quick response, man.
        No problem.
          lower stat
            Manual fan switch is the way to go.
            I have the Meziere Electric water pump and my car rarely see's above 160-180* with the combination of the two.
            The fan will help A LOT. Easy to do, and also cheap. The water pump is well worth it if you can afford it, also frees up a few hp.
              I have a 160 t-stat and lower fan settings through HP-tuners. I've never seen it go above 180. If you know someone who has hp-tuners they set the fans in 2 minutes and a thermostat is always easy to change.
              TEAM C6V6
