I'v had a ticking noise coming from my car for a while now,I thought at first it was a lifter but now after a better listen it sounds like it coming from under the car between the engine transmission,i think. The noise speeds up with the engine,but it stops once the car starts to move when in gear,its also a bit louder when put in park,and gets louder when hot,any suggestions would be great,thanks.
Help-cant figure this out
Re: Help-cant figure this out
A ticking noise coming from that area would most likely be a cracked flexplate. The easiest way to tell is to unbolt the torque converter and push it back a little (it won't move very far) then start the car again. If the ticking goes away, then you have a cracked flexplate.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
also see if the starter pinion gear is hitting the flexplate when rotated you should be able to see if the flexplate is broken just by startingthemotor and watching the flexplate it the ring gear should run in a straight line and not move front to back at all if its moving its broken or need of replacement .
Originally posted by 95 l-32 View Postalso see if the starter pinion gear is hitting the flexplate when rotated you should be able to see if the flexplate is broken just by startingthemotor and watching the flexplate it the ring gear should run in a straight line and not move front to back at all if its moving its broken or need of replacement .-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
after another listen,it seems to becoming from rigth underneath the starter,you can hear it from the top but its louder from the bottom,is this where the flexplate is located,thanks for help.
Also would a cracked flexplate make such a high rate of tick,tick,tick, noise?Last edited by LEOMAC23; 07-24-2008, 07:57 AM.
Originally posted by LEOMAC23 View Postafter another listen,it seems to becoming from rigth underneath the starter,you can hear it from the top but its louder from the bottom,is this where the flexplate is located,thanks for help.
And yes, a cracked flexplate can make a pretty fast tick, although I can't really tell you if it sounds like it or not since of course I can't hear it myself.Last edited by Skinny; 07-24-2008, 08:55 AM.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Originally posted by LEOMAC23 View PostIf I make a clip of this sound would you be willing to take a listen-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
