How do you remove the Cigarrette Lighter? - FirebirdV6.com/CamaroV6.com Message Board
  • How do you remove the Cigarrette Lighter?
    I did a search and found nothing. 01 Camaro, I have the center console halfway out however I cannot see exactly whats holding the cigar lighter in place.
    it doesnt really come out, just unplug it.
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      Yea... unplug it and check the backside of the cigarette lighter. / the console.. and see if theres any tabs that lock it in.
      I havent taken it out before but i could imagine thats what would hold it in.
      *Matt
        Did that and am sitting here with the center console in hand as we speak... problem is I need to COMPLETE remove the cigar lighter... looking on the back I see tabs and the liking but nothing happens when I squeeze them even with pliers...
          I didn't remove the lighter socket from the console, but there's an electrical plug you can disconnect in the wiring so that the console can be removed from the car.
            I did that already. The console is sitting in my lap as I type...
            Problem is for the project I'm doing, I need to completely remove the cigar lighter from the console, not just unplug it which I already did...
              i think it goes out thru the front... if you squeeze the tabs like u did. and pull it out the other direction does it wiggle or feel loose at all?
              *Matt
                You have to unscrew it, its 3 seperate peices. If you can hold the inside part then unscrew the long peice from the back side. I had to rebuild mine today. On mine that plastic ring thing that goes around it broke and the whole thing sliped inside. If you dont need it any more just break that plastic ring and it will come out. That plastic ring cost me 6 dollars today.
                  Yeh they can't make everything easy now can they...
                  Some things are a total PITA
                  *Matt
                    When I squeeze the tab's nothing happens at all... Doesn't get loose, wiggly... nothing.
                    It would be helpfull if I saw screws. I have been hammering this thing, pounding this thing, screw drivering this thing, Took a screw driver and even a pry bar and it hasn't even BUDGED. Yet I can't see whats holding it in placed. Okay it's moved ALITTLE, the top half does seem to dislocate alittle but then just snaps back in place. You think I'm hurting it? This thing is whooping my *** and has yet to attain a single SCRATCH... This is the godly indestructable console from H-E-DOUBLE-L...
                      Look at the very end of it...where it plugs into the car. It reminds me of how a light bulb screws into a lamp. You have to hold the inside part, maybe with a screw driver, i used channel locks because my plastic ring was broken. Then use another channel lock or a strong hand and unscrew it. Its 3 total peaces.
                        Like i said i just rebuilt mine today. It had it out of the car trying to figure out how to replace the plastic ring that goes around it. Even with me having it totally out if took me a minute to figure out this GM engineering. Its really a stuped setup. I was going to take pics, but i cut my finger open trying to unscrew this thing and never did. IF YOU REALLY NEED ME TO ILL UNINSTALL MINE, TAKE IT APART AND SEND YOU PICS...IF YOU REALLY NEED IT.
                          I get what he's saying...
                          it's stupid though.
                          *Matt
                            I just went and broke the damned thing off... I'll buy a new one later...
                              When you get the new one, you'll kick yourself in the a$$ for how easy it could have been ... been there, done that.
                              \'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
                                1 weeks ago
