Hey guys does anybody know how to change the lock cylinder where they key goes into. I think mine is out because the security light keeps flashing, but I wanna test it first. Anybody know how to take it out.
Lock Cylinder
Re: Lock Cylinder
From Autozone repair guide for a 93-95 Camaro: I imagine the later years are analogous. You'll need a steering wheel puller.
REMOVAL & INSTALLATION
See Figures 1 and 2
1. Properly disable the SIR air bag system.
2. If not already done, disconnect the negative battery cable.
3. Place the lock in the RUN position.
4. Remove the steering wheel. (you'll need a steering wheel puller kit, rent one or buy one)
5. Remove the lock plate, turn signal switch and buzzer switch.
6. Remove the screw and lock cylinder.
CAUTION
If the screw is dropped on removal, it could fall into the column, requiring complete disassembly to retrieve the screw.
Click image to see an enlarged viewFig. 1: Lock cylinder replacement
http://econtent.autozone.com:24991/z...52800b896e.gif
Click image to see an enlarged viewFig. 2: Lock cylinder w/VATS
http://econtent.autozone.com:24991/z...52800b896f.gif
To install:
7. Rotate the cylinder clockwise to align cylinder key with the keyway in the housing.
8. Push the lock all the way in.
9. Install the screw. Tighten the screw to 14 inch lbs. (1.5 Nm) for adjustable columns and 25 inch lbs. (2.8 Nm) for standard columns. Re-center the SIR coil assembly.
10. Install the turn signal switch and steering wheel.
11. Connect the negative battery cable, enable the SIR system.
by DongrossmdI’m new. I actually don’t own a Camaro or firebird. I do have a 2000 Camaro 3.8 fly by throttle and 4l60e. This is installed in a 1980 Triumph TR7...11 hours ago
