Cylinder 3 Misfire?? - FirebirdV6.com/CamaroV6.com Message Board
  • Cylinder 3 Misfire??
    Ok so I go and have Advance Auto run my puter on there OBDII scanner. It came back PO303 Cylinder 3 Misfire Detected. Now Im guessing that it could be several things but does anyone know? Here's what its doing, running rough and lacks full power and the engine light is on and blinking but its drivable. I'm hoping something as simple as a tuneup aka plugs,wires etc.. But my luck it will be coil,ign module etc.. Any help would be great, thanks.
    \"I told you on your first day that I was your whole family, I am your new Mother! If you maggots don\'t start getting your sh_t together, I will be forced to make myself a childless Mother!\" <br />-Multiple Unknown USMC Drill Instuctors
    Performed a search for you:
    http://www.camarov6.com/cgi-bin/ulti...c;f=1;t=015158
    Or start with checking each spark plug and wire condition. Hope this helps you out quickly.
    Black \'96 RS Camaro, 3.8 V6 Series II, M5, Stock 200 HP, 204K miles! Stock \'91 Firebird 3.1 V6 automatic w/ overdrive. 266,400 miles on it. \'83 Pontiac Trans Am,305 LG4, Cowl Induction,Borg Warner 5 Speed,T-Tops,Gale Banks Exhaust System:$800 obo
      Thanks I'll check into that now..
