anyone know the size of the crankshaft bolt - FirebirdV6.com/CamaroV6.com Message Board
  • anyone know the size of the crankshaft bolt
    I'm contemplating pulling the balancer tomorrow to replace the oil seal but I want to make absolutely sure I have the right size socket, a standard 15/16 (I believe that was the size) seem to fit somewhat snugly a 24mm seem to have a bit too much play so I'm thinking either it's a 15/16 or maybe a 23mm??(don't have that size tools jump from 22mm to 24mm :( )
    I have an 18 inch breakover bar with a 4 ft cheater pipe plan to put the car in gear and use the parking brake, have a prybar to jam in the flywheel as another resort if needed.
    Anyway I want to try to make absolutely sure i have the right size socket on before I go for this and I figured someone here who is way better at remembering these random things than I am would know off the top of their head.
    thanks
    brad
    -Brad
    2000 V-Star Custom 1100
    :rock:
    Re: anyone know the size of the crankshaft bolt
    Hmm, I can check tomorrow if you like. My dad luckily had a ton of huge sockets I had at my disposal that I found while changing my timing chain. I just don't remember what I used. I'll check it out when I get off work around noon-1pm eastern tomorrow and post up.
    Also supposedly those bolts are torque to yield which means you're suppose to replace them if you ever take them off. Well I didn't replace mine and it's been ok so far. As far as the camshaft bolt goes.. that was another story. It was also very hard to find.
    If you do run into trouble with snapping threads or whatnot when you put the bolts back on there was a reference somewhere here on this site that gave me the part number I used with gmparts.com I think it was, to get the bolt I needed.
    Anyways, I've gone overboard as usual. And as always good luck.
    TEAM C6V6
      The balancers socket is a 23mm
        haha there ya go. thanks Iwanna, you saved me like 5 minutes of my life lol.
        TEAM C6V6
          thanks guys, now do I wanna go to napa or sears, hmmmm :)
          -Brad
          :rock:
            23mm.
            Y87 Package
            MOGOB APPROVED!
            BONE APPROVED!
            VANBIBBER APPROVED!
            KRISTEN APPROVED!
            Vice Prez.
            Team Black...TEAM EMO
            Come on kids! Get a Calendar!
              You will need a new bolt since their TTY.
                anytime something is TTY that means you get a new one when you are taking it out. PERIOD. Never try and get by with reusing TTY bolts, sure it works sometimes but for the majority it is bad to reuse one.
                For the two that were debating it, the OP who started the thread received his answer for the size he needs. No need for the nonsense debating over a TTY bolt's use
                http://www.bowtiev6.com/
                  No problem, the only reason I know this is because i'm trying to get the same bolt off myself and a 23mm socket fits it lol but mine wont budge :( Stupid junk car! :spank:
                    No need to delete posts out of a thread, i didn't realize this board was censored from discussion
                    Y87 Package
                    MOGOB APPROVED!
                    BONE APPROVED!
                    VANBIBBER APPROVED!
                    KRISTEN APPROVED!
                    Vice Prez.
                      breaker bar man!
                      TEAM C6V6
                        censored from poor or misleading info, that is all. There is enough false info on this site right now, we don't need any more getting added
                          Now you got me curious as to what was said. :D
                          TEAM C6V6
                            breaker bar man!
                            Yeah, got to find my dads again. Hopefully that and a little PB Blaster will work it loose
                              Why don't you pick one up while you're at autozone tomorrow? I've got like a 3ft long 1/2in from there. It's exactly what I used to remove mine.
                              TEAM C6V6
