I just change my plugs and wires on my 96 camaro RS 3.8, there MSD 8.5mm, the stock heat sheild want fit on the end of the plug does it matter?
MSD plug wires
Re: MSD plug wires
heat shield doesn't need to go back on as long as it is not resting on the header/manifold
Re: MSD plug wires
I would leave the heat shields off, I have had the MSD 8.5mm 90 degree boot wires for several years with boot protectors worked great. I switched to stright MSD 8.5mm wires about 6 months ago with some new black heat protectors, the only problem with the straight wires is on #3 and #4 I run under the primaries on the RK sport headers. The boot protectors def. due their job, the only thing it leaves is a white mark on the boot protectors. The boot protectors are a good investment, I found a guy on ebay who sells them individually, I got mine for about $22 shipped, heat rated for 1200 or 1500 degrees(don't remember), good investment if your keeping the car awhile.Last edited by ssms5411; 07-26-2008, 09:03 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
