I am trying to find out some information about engines; specifically short, long, and big blocks. Does anybody know of a site where I can get any info on them?
engines
don't know of a site but i will tell ya what i know about them. short block is just the block, crank, pistons, rings, rods, but no heads. a long block is a short block with heads. and a big block is any engine above 400 CID i think, correct me if i am wrong on that guys.1987 Buick Grand National drivetrain in my 1993 Pontiac Firebird. PT53 turbo, 212/212 comp cam, 3400 lockup converter, stock heads, Precision bar & plate FMIC with 3\" piping, 1994 z28 rearend, hotwired walbro 255 fuel pump, Nitto drag radials
http://www.camaroengines.com/Block_Descriptions.htm
http://www.chevytrucks.org/tech/block.htm
Those 2 should give you a general idea.98 bird <br />160,000 miles<br />13\'s? Just happy it\'s starts every morning. <br /><br />Traded in @164,000 On a 2001 Formula
Originally posted by gergwheel:
and a big block is any engine above 400 CID i think, correct me if i am wrong on that guys.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
It's not the cubic inch displacement that makes the big block. The big block engine is just that, a different type of engine where the block is physically bigger than the "small block"2001 Camaro, 3.8 v6. Five speed. Red. SLP Torque arm, SLP CAI, adj. panhard bar, lcas, eibach springs, 3.73 gears and Zexel-Torsen T-2 LSD.
so its seriously just the block size? so i could have a 305 big block. sounds funny
I think big/small blocks has to do w/the size of the bore before overboring. Doesn't apply to all motors though, as the Poncho 326~455 have basically the same size blocks, jsut different bore & main size, but can interchange cams & heads (w/slight notching e.g 350 H.O.)The bastardification of Third & Fourth gen cars.
Big blocks are seriously just BIG blocks. They're HUGE. It's based on physical exterior dimensions. Displacement has nothing to do with it. The LPE 427TT Corvette uses a small block design. The small block can go well beyond 400 cubic inches though. Big block cams and cranks are longer than small block parts if that helps you understand it. Anybody want to add anything else or correct me if I'm wrong?~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
