fast question, fast answer - FirebirdV6.com/CamaroV6.com Message Board
  • fast question, fast answer
    hey guys,,,lets say i have a 3.8 and want to swap my 3.4 for the 3.8.......obd 1 to obd 2,wont the plugs of the scanner change??how wil i trouble shoot the codes if the plugs are not the same????
    Re: fast question, fast answer
    if the car is a 95, then you have an OBD II plug anyway...if not, then cant you just get ahold of an OBD II plug?
      Well if you did a 3.4 to 3.8 swap you'd need to pull the wiring harness and the computers from the doner car anyway. Which means you'd have to pull the OBDII plug in port as well.. I don't see the problem, you're just not understanding the amount of work you're going to need to do to change the engine size. It's A LOT of work, I'd re-think that decision to either modding your 3.4 or if your going to swap put in an LS1 or LT1.
        the car is 95,,,so im fine??? just run the wires as if it is the same car?? no need to go under the dash???
          Tim's right. You have an OBD II plug, but if youre going to swap the motor, you might as well put in the plug from that wiring harness...the OBD port will be a tidbit of your wiring worries...either way, you'll need to mess with the plug, now that i think of it. If you use the 3.8's plug...you'll have to...and if you use yours, you'll have to get the the back of it, run the wires in and wire the plug up. just swap it all out.
            that plug,is straight from the pcm to under the dash??? or it has to go to the fuse box and so on until it reaches under the steeringwheel??
              Part of it goes to the PCM, part goes to the fusebox and elsewhere.
              -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
                swapping engine is no easy task,,,,,better if a buy it rather than swap it!!
