Water leaking passenger side, think its the AC. Where is the drain? - FirebirdV6.com/CamaroV6.com Message Board
  • Water leaking passenger side, think its the AC. Where is the drain?
    Hi All,
    Yesterday while driving (AC on all day) I took a right turn and my girlfriend said some water dripped onto her legs. Had her drive around the block and sure enough as soon as we go up a hill and take a right turn more water dripped out onto to passenger rug. I pulled off the panel under the glove box felt around and it was wet. The water was cold and didnt seem oily so I assume it is from the AC and the drain plug for the AC must be plugged. Can someone tell me how to unclog it (without getitng under the car it possible). Where is the location I can blow some air through to unclog it and where is the tube underneath if I have to get under? I tried a search but couldnt find a post that showed the location of where to blow it out or where the drain is underneath. Thanks in advance!
    And yes I realize my forum name is missing a R :mad:
    Thanks!
    Eddie
    Re: Water leaking passenger side, think its the AC. Where is the drain?
    You'd have to get under the car to reach the a/c drain. There is a small (maybe 1/4"?) hole on the bottom of the HVAC box (the big plastic box sticking through the firewall on the pass side). There is no tube or anything coming off of it, just the hole.
    -<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
      Had to be evacuated again due to fire
    • RPDRed6
      For Sale: 2001 Chevrolet Camaro project.
      by RPDRed6
      Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...
      No start problem
