about a week agao I took my throttle body apart and cleaned and painted it. now my gas pedal sticks every time you start the car up, I cleaned and check all around the spring and bump stop and can find whats wrong...any help would be great
throttle cable sticking
Re: throttle cable sticking
Did you put your TPS sensor in right? I would check that first, you have to put it in the rotate it towards you, then put the bolts in.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
If you just put it in without turning the TPS sensor towards you it is in wrong and you rpms will stay high until it is in right or your linkage is messed up.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
You might check the IAC? Don't know if you replaced that one or not. If not then spray it down with some brake cleaner or carb cleaner and wipe it down.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Yeah, I don't know if it is not one of those or the cable linkage, Do you have a cruise control linkage on your TB hooked up?08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Is it sticking OPEN or CLOSED?-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
Check the adjustment on the throttle blade. If it closes too far it will stick. Also make sure the inside around the throttle blade is clean.-<i>Travis</i><br /><b>99 Trans Am, Pewter, A4</b> Forged, stalled, and cammed<br /><b>85 Buick Regal WH1 T-Type</b> It\'d be cool if it ran...<br /><b>94 Camaro 3.4, Teal, M5</b> The daily beater
