To replace sway bars, it is recomended to raise the car on jack stands. I have a phobia to be under the car with those things. I feel safer if I use ramps. Can I used them to replace sway bars, and possible the panhard rod?
Sway bars and Jackstands
Re: Sway bars and Jackstands
you can change the rear without even raising the car at all and if you are skinny enough you can do the front's without raising the car either it's just easier with it in the air because there is more room.
Either way you don't want to tighten everything down until the car's weight is on the suspension, this is really important to ensuring you don't put anything in a bind.-Brad
2000 V-Star Custom 1100
:rock:
Mmmmmm... maybe. There's no tension on them. Might be a bear to get to them and get them to line up. Can't say for sure though.
Originally posted by black98V6 View Postyou don't want to tighten everything down until the car's weight is on the suspension, this is really important to ensuring you don't put anything in a bind.
Lounge Moderator
Originally posted by black98V6 View Postyou can change the rear without even raising the car at all and if you are skinny enough you can do the front's without raising the car either it's just easier with it in the air because there is more room.
Either way you don't want to tighten everything down until the car's weight is on the suspension, this is really important to ensuring you don't put anything in a bind.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
