starter solenoid. - FirebirdV6.com/CamaroV6.com Message Board
starter solenoid.
  • starter solenoid.
    This question is actually for my f150, but its a pretty general question. When I go to start it, all it does is click and the clicking is coming from the solenoid, not the actual starter. does that usually mean the solenoid is bad or does it not matter where the clicking is coming from?
    Re: starter solenoid.
    also i wanna add that my security light is blinking when this happens (searched and that was mentioned in a old thread) I cant figure out how to get it to stop blinking because i have auto locks but the auto locks dont work.
      take it out of the car and take it to autozone. they will test it for free.
      WAWA-A-HOLIC
        if it's like the old school Ford starters where the solenoid just pull the cable off the starter side and use a jumper cable to bypass the solenoid. Use caution though because you can shock the **** outta yourself.
        I think the security light will blink until the car starts, at least that's how it works on the wife's ford.
        Also typically what you are talking about, click but no start means you don't have enough amps to turn over the engine, see if you can jump it, also check your cables for loose or corroded connections. My experience with fords are that when the starter goes it's usually the bendix which means you hear the starter spin free but the engine doesn't turn over.
        If the security was killing the starter you wouldn't even get the click.
        Result, bad battery or bad connection.
        -Brad
        2000 V-Star Custom 1100
        :rock:
          I would definitely start with checking the batt terminals and cables for ANY corrosion. Wire brush them so they are nice and shiny. I've had terminals that don't look bad, but it's enough to cause problems.
            well batterys good and solenoids good and i didnt see any corrosion but i didnt check all the way down to the starter. so gunna do that tomorrow and if its all clean, bad starter.
              you can have a bad ground and not see it, especially true if it's an older vehicle. If you had a good multimeter you could test the amp draw on the starter. Also check for a loose connection at the starter.
              -Brad
              :rock:
                it was a bad starter. starts fine now that i replaced it.
                  cool, glad it worked out
                  -Brad
                  :rock:
                    how can you shock yourself with DC current
                    unless you are trying to do this in a swimming pool...
                      good question. all it did was make a few sparks.
