AHHHHHHHHHHHHH
did some curseing last night and got to hooters and oil was spilling out on ground car smokeing like mofo
1. its not coming from the tranny housing so rear main is okay
2. not turbo supply
3. not turbo drian un less its sparying oil out a pin hole or somthing
4. not turbo seal no oil smoke out the exuast
5. so WHERE THE **** IS IT
i think it's oil pan gasket or timing cover gasket......
any other thoughts?
its not small i lost 2 quarts on the way there and one on the way home..... i'm not sure if boost make it leak or just higher RPM (did not boost on the way home)
2. not turbo supply
any other thoughts?
