Tires will not spin...something wrong? - FirebirdV6.com/CamaroV6.com Message Board
  • Tires will not spin...something wrong?
    Driving a hot Camaro, its not unusual to have friends who want you to "smoke them up" Ever since I got these new Fuzion HRi's my tires refuse to spin. Even pulling out of a parking lot or something with the wheel cut all the way in one direction i may get a small chirp but nothing more. Flooring it from a stop gives me a very violent shaking and loud noises. So tell me, is it just where my tires are new? Or is there something wrong?
    1998 Camaro V6 \"Black Mamba\"<br />Y87<br />Whisper Lid w/ K&N filter<br />Flowmaster American Thunder<br />Numerous appearance mods.<br /> <a href=\"http://www.cardomain.com/ride/2154172\" target=\"_blank\">Car Domain</a>
    If im pulling out of a parking lot with my wheel cut ALL THE WAY, i can burn mine for a few seconds. If im at a stop light on dry gound pointing straight, it will chirp. I dont know much about tires but mine are new yokahma yk420...i dont know if that spelling is correct. As long as the car runs and idles good i would not worry about it.
      If you guys are running 245s or smaller and having trouble spinning the tires... something is going on with your car.
        AMEN!
        If you have a M5, I'd replace the clutch. If an auto, I'd have it serviced. If there are no probs with the trans in general, I'd give the engine a full tuneup.
        I got 275-40-17's (without a lot of mods) and I can STILL light the tires up with my V6!
          Might want to check your transmission mount. Having one that's shot can hamper burnouts.
          1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
            sound like wheel hop you need new LCA's
            www.turbov6camaro.com
            1997 3800 Series II Camaro
              Ok, you guys are going to have to take in easy on me with the drivetrain lingo. I know a little about engines, but hardly anything about trannys.
              What are LCA's. And yeah, if I could describe the violent shaking, I'd say it was "hopping". Where can I find the transmission mount?
              It is an A4, btw. And i've had my suspicions about my tranny being tired...damn...maybe it is time.
                LCA stands for lower control arm. You can order a new quality tranny mount from NAPA.
                  Originally posted by Bearkat:
                  </font><blockquote>quote:</font><hr />Originally posted by Greg94Red392:
                  LCA stands for lower control arm. You can order a new quality tranny mount from NAPA. </font>[/QUOTE]Any way I can tell for sure what it is before I go out and buy something I dont really need?
                    </font><blockquote>quote:</font><hr />Originally posted by Bearkat:
                    LCA stands for lower control arm. You can order a new quality tranny mount from NAPA. </font>[/QUOTE]Any way I can tell for sure what it is before I go out and buy something I dont really need? </font>[/QUOTE]You were right on the dot, saying you had plenty of "hopping."
                      If you jack up a bit on your transmission, you will be able to tell if the piece mounting it to the cross-member (tranny mount) has failed. It should be all in one piece without any deep cracks.
                        check your tire pressure... the more you have, the easier it'll be to spin 'em
                        I like 35 psi, gives decent fuel mileage and normal tire wear.
                        Laying rubber is not as cool as 17 year olds think it is.
                          espically when you have to dump the clutch or go arround a corner to get them spinning.
