i am having problems with my pass key system. I was reading this and it sounds like what i am going through. it does it to my like every other time. i dont have a sapre key. can i bypass it with a resistor on a 98 model. i am hoping it will. can anybody tell me how to check for the resistor i need.
VATS bypass
Your best thing probably would be to get an omega remote start bypass module and just hook it in to go on with the ignition, but yes you could just do a resisitor using the right amount of ohms2002 M5 Bright Metallic Silver <br />*Fully loaded and modded<br /><br />2005 GSXR 750<br />*Micron Serpent Race Exhaust *K&N Filter *Power Commander *Trying to hit 200 MPH!<br /><br />1970 SS 454 Chevelle Cortez Silver<br />*It can pass anything but a gas station
how do i check for ohms can i just have the key and checkStarting Left Guard For the Blacville-Hilda Hawks 1A State Champions<br /><br />Mods: Free Ram Air, All Lights mods, K&N <br />Coming Soon:Flowmaster American Thunder Catback, Whisper Lid, HighFlow cat and Maybe Headers
Check out thePellet Value link and the Bypass Diagram link ... they should help you out. Good Luck !!!\'97 Firebird 3.8 ... 1/4 mile = 12.50 (minutes)
you sure can bypass it with a resister from radio shack. Use a meter on the ohms setting, looks like an upside down U. Put your meter one each side of the chip in your key. My key reads 883...i think if i rember correctly. Take your ignigion out, and put that radio shack resister on each side of the pink wires. Your done.
[ January 30, 2006, 10:13 AM: Message edited by: BobbyZ72 ]<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
you sould read one of these when you test you key.....#1 0.402 2 0.523 3 0.681 4 0.887 5 1.130 6 1.470 7 1.870 8 2.370 9 3.010 10 3.740 11 4.750 12 6.040 13 7.500 14 9.530 15 11.801<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
look here the wires you put the resister on look white on this one... mine looked light pink... http://cgi.ebay.com/ebaymotors/1994-...spagenameZWD1V<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
mine read 889. i didnt see any close so i put a 1-680 and 2-100 ohm resistors together and its worked fine. but i wired mine to teh plug under the dash not in the column. its was very simple and saved me some money. BYPASS COMPLETE. its working like a charm. Thanks for asll the help everybody.Starting Left Guard For the Blacville-Hilda Hawks 1A State Champions<br /><br />Mods: Free Ram Air, All Lights mods, K&N <br />Coming Soon:Flowmaster American Thunder Catback, Whisper Lid, HighFlow cat and Maybe Headers
