Replacement Fuel Injectors - FirebirdV6.com/CamaroV6.com Message Board
  • Replacement Fuel Injectors
    Ok. Amongst a few other problems found at the shop, they finally figured out why the car has such a rough start and the horrid stench of raw gasoline. I have at least one leaky injector. This is no surprise, they already have 84,xxx miles on them. But, I was quoted $150 PER injector for a replacement, as well as labor of diagnosing which ones have gone bad. I got a second opinion and they said that sounds about right. But I've seen injectors for much more reasonable prices on here, both used and new. Right now, I just want to know what my options are for replacements, OEM and aftermarket. What are some good brands for a stock weight fuel-injector? What are some brands that have worked well for you?
    '99 Camaro
    '04 Saab 9-3 Aero
    '90 Audi Coupe Quattro
    Re: Replacement Fuel Injectors
    I have not got new fuel injectors yet, but I have had the leaky injector problem.
    Eventually, I'll get new ones, but temporarily I just replaced the O ring which was the issue anyways.
    Do you know if its your O rings? Cause you can replace those really cheap.
    Although, since you'll have them out, probably best to replace them anyways.
    But if money is tight, you can replace the o rings, if that is the issue with them leaking.
      I have a set of stock injectors for sale right now. Only 45,000 miles on them.
      $25 shipped.
      BTW, injectors shouldnt go bad at 84k miles.
      1997 Camaro RS A4
      2006 Chevy Colorado
      2003 Kawasaki Ninja ZX6-R
        $25 shipped.
        I may have to take you up on that. I went to the local NAPA store and found that I could get new stock ones for $86 per, but that's still a little high. I have to pay for a few other things first, but that definitely seems like a good deal.
        And I'll have them check the O rings. Those were dirt cheap at Napa.
        '99 Camaro
        '04 Saab 9-3 Aero
          Just PM me when/if you want them.
          1997 Camaro RS A4
          2006 Chevy Colorado
            Ok. Thanks. :)
            '99 Camaro
            '04 Saab 9-3 Aero
              Check Summit Racing you should be able to get a set of Accel for around $250. They aren't that hard to change. I have a set of Accel that I think are 22# for sale if you're interested. If your car is stock it will run a little rich which is why I took them out of my 99 Firebird 3.8. They only have about 50 miles on them.
                Thanks for the offer, but I got a spare stock set from another member. That and my car runs rich enough as it is with one leaky injector. Don't need anything heavier.
                '99 Camaro
                '04 Saab 9-3 Aero
                  how are they working? its odd that Accel injectors make it run rich.. after all stock injectors are 22# also.
                    wow, his car has no year of production. thats a very rare thing indeed. no wonder they wanted an arm and a leg. :banana:
                    01 Firebird A4 3.42
                    Powerdyne @ 6 PSI
                    and other mods
                      yeah.....ZZPerformance has full matched sets for 150 bux.
