Some problems after cleaning TB... - FirebirdV6.com/CamaroV6.com Message Board
  • Some problems after cleaning TB...
    Went about cleaning the TB today, all went well till i started the car. Car idled at 3000ish so i shut it off and went around looking to see where i screwed up. Ends up i put the TPS sensor in backwards. So after fixing that, i restart the car, it idles normally. I take it out for a spin and i notice the throttle is really sensitive. When i give it about 1/4 throttle, the car starts to idle at 3000 again. Replaced the TB gasket with a new one, so i don't think its a vac. leak. The hose from the IAC to the TB did have a crack at the end where it plugs into the TB, but i used a hose clamp and i think that did the trick for now. If there IS a leak there its small, not one that would case a 3k idle. Anyone got some suggestions about what's wrong?
    Oh and, it threw a code at first:
    DTC P0122 Throttle Position (TP) Sensor Circuit Low Voltage
    I assume that's because it was in incorrectly?
    Re: Some problems after cleaning TB...
    yes just curious what year car is this also check to see if there is a vacuum leak spray some brake cleaner around the area where ever the vacuum leak is it will either idle up or down depending on what kind of brake cleaner you have
      98 camaro.
        okay well check the vacuum leaks also check the throttle cable for binding\improper install
