Ok i got my switch installed today. When i have the switch on low speed both fans run on low speed. When i have the switch on hi speed only passanger fan runs on high speed, drivers side fan is off. Is this correct?
Fan speed question
Fan speed question
<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.Tags: None
http://www.cardomain.com/ride/2245261 that is what i did,, maybe i didnt do it right.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Thanks!! [img]graemlins/banana.gif[/img]<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
Originally posted by StrtRacer98:
what wires did you tap into?
can you just buy a switch and tap into something or is there actually a control box or something?<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
this mod cost my less then 7 dollars with wire, spdt switch, shilded connectors. and about an hour... took the longest to find a sutable location for the switch.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
the switch i got from radio shack, but all auto parts sell the same switch. ITs called a spdt switch. Thats Single Pole, Dubble Throw. On the switch it will say ON-OFF-ON. put your ground wire on OFF, and one fan wire on ON and the other fan wire on the other ON. Look at my pics, i tryed to make it as simple as i could.<a href=\"http://www.cardomain.com/ride/2245261\" target=\"_blank\">http://www.cardomain.com/ride/2245261</a> Green 1997, 105k, all stock except for Z28 front springs, Air shocks in the rear, home made coolant recovery tank, home made battery hold down.
