Alright, every once in a while when I start my car it'll idle high at around 2-3K RPMs. It'll also throw the SES light and it comes back with a TPS code. Car runs perfect, except for the high idle. It goes away usually within a minute, and doesn't do it again that run. It doesn't do it after it's warmed up, it's just random cold starts. I replaced my TPS, so I'm thinking it's a vacuum leak somewhere; that rubber elbow that goes onto the TB is rigged on ATM because I can't find it anywhere, and I'm thinking that might be my problem. Either that or a bad IAC, what do you guys think? I'm hoping to get my scanner sometime soon, and hopefully get some sensor readings when it does it.
High idle and TPS code
by Need4CamaroThe panel under the HVAC controls where the button is supposed to be is completely missing when I bought the car so I dont know if this car had TCS or...3 weeks ago
by Need4CamaroI was wondering, are these cars DBC or DBW?
If swapping in an LS motor (lets ignore the rest of the complexity of the swap), what would be...3 weeks ago
