Idle rpm flucates after startup - FirebirdV6.com/CamaroV6.com Message Board
  • Idle rpm flucates after startup
    Would anyone know why my 3.8L 02 camaro's rpm would flucate up and down after starting the engine?
    After about 10seconds it smooths out to normal with no other flucations until the next startup.
    Nothing major, maybe only 200rpm's or so.
    Thanks for any advice.
    Re: Idle rpm flucates after startup
    sounds fairly normal to me
      Do you have an aftermarket air intake? Maybe a small vaccum leak of some kind...could be a lot of things.
        what he said.
        The car will also idle a littler higher when its cold
          I do have an aftermarket airbox, could it be that sensor that attaches to the airbox? It never did fit very well.
            it is a normal thing, dont worry about it.
