low oil pressure problem - FirebirdV6.com/CamaroV6.com Message Board
  • low oil pressure problem
    I have a 94 3.4 5 spd firebird. Has 133k, cold air, stock otherwise.
    My problem is that when i first start driving in the morning im reading 40 to 60psi oil pressure, after about ten mins when the engines warm it drops down to about 5 at idle and 20 to 30 when driving. Im pretty sure thats not normal, what is?
    There is no knock or any noise whatsoever coming from the engine other than a small exhaust leak somewhere. I have a feeling its not the sensor because i feel a difference in acceleration and engine vibration. First thing in morning it runs smooth. Warms up and its rough vibration and slower accel. My oil is full, regular oil changes.
    I do smell oil burning when i get park and get out, its coming from the engine just dont know where, its not bad enough to drip to the cement, i let it sit 2 days and not one drop.
    Any advice i would greatly appreciate, anything i can do til then a thicker oil like 10w40? Lucas?
    thanks
    Re: low oil pressure problem
    running thicker oil is just going to cover up a potential problem, and may cause further engine damage
    also lucas isnt going to do anything good for your engine.
    im not familiar with 3.4's so i have no idea what the normal operating temp oil pressure should be
      Still, you need to verify pressure with a mechanical gauge first before doing anything else. If the gauge confirms low pressure, then it's time to investigate further. Don't go tearing into things w/o being absolutely sure that the problem is mechanical.
        2 days ago
      • Doodler
        97 Camaro base with expensive sounding noises
        by Doodler
        Still trying to find oil leak
