Is there a way to tell if you are running lean? - FirebirdV6.com/CamaroV6.com Message Board
  • Is there a way to tell if you are running lean?
    See mods below. I ask this because sometimes when I'm in 2nd gear driving slow (automatic) and punch it, it taks off like a bat out of hell, but it seems to cut out after reaching high RPMs right before the shift. It just goes quiet for a SPLIT second then shifts like normal. Thoughts?
    <br /><br /> <a href=\"http://www.cardomain.com/id/nitroxxx28\" target=\"_blank\">http://www.cardomain.com/id/nitroxxx28</a>
    If you want to check to see if you're running lean, pull a spark plug out and see if it's white. That's a good indication you're running lean. Other than that, I haven't a clue how to diagnose automatics. Could be a speed sensor on the transmission or something else....I dunno.
    Nitrous is like a hot chick with an STD....you wanna hit it, but you\'re affraid of the consequences...<br /><br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=244935\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=244935</a>
      yeah what kahouna said about the spark plugs also you would smell a roten egg smell if it was running lean enough.
      Later,
      Mike
        If it's hesitating before shifting at WOT, might be your transmission telling you that it's about to take a dump.
        Big cam. Big stall. Big nuts.<br /><br /><a href=\"http://www.streetlethal.net/vids2/joenastycam.MPG\" target=\"_blank\">Idle/Rev Clip.</a>
          :( Rev limiter..... [img]graemlins/crybaby.gif[/img]
          Zobe
            I smell egg a mofo, but I figure it's because I've cut everything off behind my cat and welded in a turndown. REV LIMITER!!! BINGO! I never even thought of that! Thanks.
              Get an air/fuel ratio gauge. cheep one from auto zone is about $30 or autometer I would say $65+
              1999 Camaro V6 A4<br />Navy Blue metallic<br />Intake+Exhaust+4.10+?=?
