flasher bad? - FirebirdV6.com/CamaroV6.com Message Board
flasher bad?
  • flasher bad?
    i noticed that my left turnsignal started to flash a little slower than normal. and today when i tried to use it, the light just stayed on
    got out of my car, turned the turnsignal on, walked around back, just normal lights, no flashing, walked around to the front, and i see the front sidemarker light flashing, so i figure just the back bulb is out, then when i go to shut my car off, i see that it is flashing now, and the back was also
    is this a sign of the flasher going bad? or do have a loose bulb, or what??
    Re: flasher bad?
    ok, here is what is happening
    its only the left tursignal, when i first put it on, it stays solid anywhere from 5-10 seconds, then it will start flashing again
    anyone know whats up? i figure if the flasher is bad, it wouldnt flash at all, but i have no idea
    thanks!
      Re: flasher bad?
      Probably the flasher,put the electronic one in they are only a couple bucks more.
      Take off the lower panels below the steering wheel,you cannot see the flasher even if you hang upside down.
      Reach up between the steering wheel and the radio and its tucked in a bracket behind some bracing.
      Have fun. ;)
        Re: flasher bad?
        are all the other ones ok
        WAWA-A-HOLIC
          Re: flasher bad?
          yeah, and now i see that there is only two flashers, one for the turnsignals and the 4 ways
            Re: flasher bad?
            Only 2?
            Isn't that enough?
