Yesturday my 01 camaro started to make a humming noise from the rear of the car i am assuming it is from the fuel pump it will make the humming noise for a couple of secounds then it will go away and come back every so often is that an early sign that my fuel pump is getting ready to crap out on me any info is helpful
Noise from the fuel pump
Re: Noise from the fuel pump
Originally posted by Qwesboy View PostYesturday my 01 camaro started to make a humming noise from the rear of the car i am assuming it is from the fuel pump it will make the humming noise for a couple of secounds then it will go away and come back every so often is that an early sign that my fuel pump is getting ready to crap out on me any info is helpful
i just rolled a 100,000 on it yesturday then it started making the noise
Now with that fuel pump does that just replace the orignal one in the tank or how does that work and is it supost to help with performance not to sound stupid
my dad's 02' impala has had two fuel pumps that have made the humming noise
they said that there have been a lot of complaints about that.. im not sure if they are the same pump though.
also, try replacing your fuel filter first, it may be pretty bad and is making the pump work extra hard
Originally posted by Qwesboy View Postso what his car has gone threw 2 fuel pumps already but they never went complety out how many miles does he have on the car
the first one made the noise, and he took it back during warrenty, at about 40k miles, they replaced the fuel pump, regulator, and the filter
the new pump didnt make the noise, then started to, but my dad just delt with it, it did seem to only make it while it was warm out though
it made the noise for two summers, and hasnt made it yet this summer
also a few months ago, i heard a humming noise from the pump in my 98' but it only did it for a day and hasnt come back since, and after about 3000 miles
I have also noticed this noise just a couple of times. My car has about 27,000, but the noise only happens when it is hot and I have been driving it for a while on a low tank of gas. I usually try my best to keep the tank over 1/4 full. I do not think the pump is faulty, since it is still fairly new, but the factors I listed most likely cause it to overheat and hum.2002 Camaro A4<br />K&N FIPK<br />Ravin exhaust<br />15.64 @ 90.11 MPH<br /><br />_ _ ___________________ _ _ <br />2004 Quicksilver/Black GTO M6<br />Stock except !CAGS
