Every time it rains my car misfires like crazy i replace 2 coils and driver side of wires and plugs.. Is there any thing eles that would cause this.. ICM, other coils, wires gettin water? Crank sensor gettin wet?
i havent seen what ones are misfireing now but
i need this Fixes asap
Sounds like you need to fix the water getting in there first before anything, I had to use some silicone under the cowl to fix my leaks. I was getting misfires when going though the car wash, after siliconing it, no more misfires. It doesn't matter if your running MSD 8.5mm wires with super coils , If water is getting in it is going to misfire. Fix the water getting in first.
You can use the Pertimex(spelled wrong I know) black silicone, I pulled the cowl off, washed off all the dirt. Then just where the outline of the metal goes on the car put a small bead of silicone, let it dry. Then the black weather stripping I ran a small bead across that, or I ran it under it , don't remember. But It came out fine, never had anymore misfires or any spots of water on the engine.
so she pulled her car in the garage and said it was sparking from the 4-6 coil.. gona hopefully play with it some time soon.. replace ICM and redo the plug boots..thanks all
